Why is website data still filling up in in When private browsing mode?
You will help your issue(s) by correctly providing information re your computing device and its OS, plus version of Brave Browser - as required by Brave Support, when you are creating a report.
I brazenly stole over 99% of the following, from Brave Support Team Member, @Mattches:
Please EDIT your Original Post ("OP") and topic title above, in order to reflect the Template and Guidelines (following), and Brave Support will be more likely to assist you.
Guidelines - Before posting, please:
- Search the forum to see if anyone else has already posted or resolved the issue you came to ask about.
- Fill out the template that appears in your editor when posting as it contains all the boiler-plate information surrounding your issue. It will help the Support team members and other Community members to efficiently assess and resolve your issue.
- Provide essential info such as your version number and OS, to help Support and other Community members resolve your issue.
- Ensure that you’re posting in the appropriate category
- Tag your post appropriately – note that some tags are restricted to or from specific categories.
- Observe and adhere to our code of conduct
In order to help you become acquainted with how the Brave Community’s Discourse software - the general forum, user interface (“UI”) - works:
Ok sorry I am new to this
I am using IOS 15.1 both iPhone and iPad,
And brave 1.37 (22 4 6 8)
The problem is very repeatable as when browsing privately website data is still being collected.
What ‘website data’ is still being collected?
How are you observing that ‘website data’?
Just so you know, there are many websites, that you may visit and find that ‘website data’ continues to be downloaded from the website (and its associated servers / other websites assisting).
Thanks for contacting me back.
The website date is cache , cookies and local date, I am surprised as in private mode I would have thought this should not be recorded
Thanks
Some of that data is temporal, when using Brave Browser > New Private Window.
But a user might improve on the clearing of it, or inhibit clearing it, depending upon various Brave Browser > Settings.
In a Brave Browser > New Window, go to: brave://settings/clearBrowserData
. . . and look over the settings for the Advanced and On exit tabs.
In a Brave Browser > New Window, go to: brave://settings/cookies
- Enable:
Block third-party cookies
- Disable:
Clear cookies and site data when you close all windows
- Remove all:
Sites that clear cookies when you close them
Those are my choices, based upon experience.
I prefer manually clearing cache, cookies, and site data, when I suspect that I should:
Return to: brave://settings/clearBrowserData
For tab Basic - set:
Time range:All time
- Enable:
Browsing history
- Enable:
Cookies and other site data
(Signs you out of most sites) - Enable:
Cached images and files
Click on the “Clear data” button.
(The “Clear data” button also saves the selections.)
