I have 2 issues, after installing android brave 1.73.101 on a (old phone) Samsung S9 and a (new phone) Samsung S24.
ISSUE-A On both phones, I find that the Sync is NOT syncing the passwords that were stored prior to entering the sync chain. It only sync newly added passwords (editing existing passwords in Password Manager does not enter them to the chain, they really have to be picked up as new passwords, while I enter them in the website login form)
ISSUE-B. On the new phone (S24), I notice that any password that is synced via chain is DELETED when I leave the chain (so both passwords received by sync; and those sent out via sync). (I did not test that on the old phone, as I don’t want to risk deleting all passwords).
sidenote: I was eagerly waiting for this version 1.73.101 as on the previous version (.97 and earlier) I was suffering, only on the S9, from the problem of not being able to turn on Password syncing
cfr DISCUSSION Can't turn on password sync
cfr ISSUE TICKET https://github.com/brave/brave-browser/issues/36190
I hesitated making 2 posts about this (as there are 2 distinct issues), but I suspect it’s related.
- on device X make sure to have some saved passwords, and not being part of a chain.
- create a sync chain, enable (also) password syncing
- observe brave://sync-internals => the “entries” under passwords remains 0
- go to any website with a login that is not yet saved
- perform login and allow brave to save the password (brave should show a popup)
- observe brave://sync-internals => the “entries” under passwords goes to 1. This establishes issue-A
- sync another “empty” device (Y) to that chain, and see the password from step 5-6 arrive in the password manager.
- leave the sync chain on device X, and observe under Password Manager that the password saved in step 5 is gone.
- leave the sync chain on device Y, and observe under Password Manager that the password saved in step 5 (and synced to device Y in step 7) is gone.
Steps 1-9 establish issue-B
I’ve also tested this with just 1 device, SKIPPING step 7 and 9.
every time, tested a 2-3 times so far.
Brave Version(See the About Brave
page in the main menu):
Type of devices currently running on the Sync chain in question:
Only Android brave 1.73.101
contact me for more.
On the old phone, I was using Brave for 6 years; but only started using sync in the last 2 weeks, to copy over the data to the new phone.
