Since the upgrade of the brave browser this month, the sound of videos have become extremely quiet, I have tried other browsers and the sound quality is fine.
Can anyone help with this issue ?
Kind regards.
Kind regards.
could you disable all extension and see if it help or not
and have a nice day
Hello, unfortunately disabling my extensions did not work, I only have 1 or 2 extensions. Duck duck go, and meta mask.
Thanks for your help and have a nice day too
you welcome and thanks
did you check the sound setting in the windows task bar maybe there controller to increase it
try to play any video or music and see if it work or not
I found the problem in the sound mixer, thank you very much for all your help!
glad it work and you very welcome
