I used to have such a problem which I got rid of using MalwareByte but this time it does not work. when I make any research using bar I’m redirected on Bings searchengine instead of the nomrla duckduckgo I normally use but before being sent on bing, I have for on second the Searchbarin that appears and dispappears.
do you know how I can get rid of it in Brave as malwarebyte seems to have already get rid of it in my mac ?
Thanks but unfortunately it does not work, I removed everything but duckduckgo, that’s unfortunate, I think I just have a maleware which I cannot get rid of
You’re not annoying at all, but the situation doesn’t look good so far.
Was the fresh user profile the only active window when you tested after creating the profile? If there was another active window from the old user profile, re-check once again but this time make sure the only active browser window is that of the new user profile.
Open the fresh user profile → right-click on the blank space just above the address bar → Task manager → take a screenshot and provide it in the next comment.
Unfortunately that I did many times, but it’d keep changing te search engine, it’s like searchbaron for a second then bing or ask all of a sudden, only in my main profile really strange
Check whether disabling extensions and then clearing the browsing data will have a positive impact.
Fresh user profiles come without any browsing data and extensions. If the issue isn’t present in a fresh user profile, it’s very likely an extension or/and browsing data cause issues in the original user profile.
