In addition to creating a new profile, try in a new private window and see if the behavior still occurs in a private window
Please confirm that you cleared history/cache for all time on the Advanced tab at brave://settings/clearBrowserData. Try exiting, waiting a few, and reopening Brave if you haven’t closed Brave since you cleared history/cache.
Provide your OS version
The above information will help troubleshoot. Please post an update. Thanks!
Great support here. Knowing your OS would definitely help. I’d test the Private Window first, before creating a new profile (which you should still test if the Private window doesn’t work).
I’m actually more inclined to think this is a Hardware Acceleration issue or perhaps an extension issue, if you have any installed in the browser at this time. So after telling us your OS, please try the following tests:
Test the behavior in a Private browsing window
Disable HWA (Settings --> Additional --> System --> Hardware Acceleration), then test the behavior
Disable any extensions you have installed at this time then test again
@chonka,
Glad to hear the issue is resolved — I’ve reported the behavior to the team for review in the event there is anything we can do about this extension causing the issue. Thanks for testing and letting us know, and don’t hesitate to reach out again if you have any questions or concerns.
