Problem with paypal in brave
When paying for good on line find that paypal webpage does not work in brave broswer.
Please can you fix this issue.
Thanks
I have used paypal three times now with no issue in Brave. Did you try logging into paypal on another tab? That makes things so much simpler. Crypto wallets might be causing problems if they also accept crypto, I keep it disabled until I need it.
Hello,
thanks for getting back to me, can you tell me how I disable Crypta wallets.
Thanks
Matthew
Open up settings, on the left click Extensions, or just go here: brave://settings/extensions
On the right turn off “Load Crypto Wallets on startup”. It’ll auto start when you need it, and it’ll make you log in before using it, instead of starting when you start Brave.
I used Paypal without problems.
Thanks
I will do this.
Thanks
Matthew
