I think it started a week ago, whenever I click on a link, a sound plays. Since I worked with headset is getting quite annoying.
In the beginning, I don’t mind, but it started to grow and now I can´t get it anymore.
It´s not always, neither every link that I clicked, I can’t seems to replicate to detail more to you. Apparently in Private mode doesn’t happen. Neither on Chrome.
I refuses to use Edge even for test purposes.
My Brave details is:
[Version 1.50.114 Chromium: 112.0.5615.49 (Official Build) (64-bit)]
in a Windows 10 system.
I already try to disable Navigation sounds in Windows settings. No success in that approach.
Anyone has any idea?
Thanks.
Could you try in a new profile?
if it only happens on certain sites it could be part of the site, javascript or some such.
@SmartAadi I do not use profiles. DO you think I should create one for
test sake?
@Lowner - Definitely not part of the site. Imagine, I’m hearing when I
click to read an email on Gmail. Or read the news on a digital site. That’s
how bizarre the thing is. There is no reason at all.
Thiago Simões
thiago.simoes@gmail.com
thiagosimoes@gmail.com
