Since a few months, i have an issue with my Brave Browser. The sound is not played anymore on all of the websites i can visit. It’s working only when i’m using a bluetooth speaker instead of my laptop’s speakers. I have this problem only on Brave and not on other browsers( Firefox, Chrome) so if the problem doesn’t go away I’ll have to give up on Brave …
Windows 10
Version used : Version 1.5.115 Chromium: 80.0.3987.149 (Official Build) (64-bit)
Thanks for your help, i’ve looked for a solution but didn’t find anything…
Hey! Thanks for your help, I tried changing the profile as u said, and even as a guest but it doesn’t change anything …
Can you try going to your sound settings:
windows settings --> sound --> advanced sound options --> app volume and device preferences, and adjust the settings for Brave.
Thanks a lot!!! I just reset the sound settings where u told me to do it in the windows settings and it worked! Really thank u!
