Briefly describe your issue:
Recently verified wallet on one computer with Gemini. Brave rewards balance went to 0 and then BAT showed up in Gemini ~15 minutes later. From what I understand this is the expected behavior.
This afternoon I tried to verify my wallet on a second computer with the same Gemini account. Instead of going to 0, the wallet balance immediately reflected the sum of the BAT in my browser + the BAT in my Gemini account. It has remained this way since then which was several hours ago. This is reflected in brave://rewards-internals/, where it shows my Gemini balance and my rewards balance separately.
Based on the logs, I suspect there is an error based on the fact that I copied my brave profile over from an older third computer to this second computer after that third computer died and I had to recover my data from the hard drive.
OS information:
Brave version: Version 1.29.77 Chromium: 93.0.4577.63 (Official Build) (64-bit)
Yes
9/6/2021
N/A
Are you using a VPN? (yes/no)
No
Yes
N/A
N/A
