Briefly describe your issue:
I had been using Brave for months with no wallet verified or connected and accumulated roughly 15 BAT. I was waiting to reach the minimum threshold of 25 BAT to verify my Uphold wallet, but then realized I could link my Gemini wallet at any time. Upon linking my Gemini wallet, my BAT balance within the browser was reset back to 0 BAT. No BAT show in my Gemini wallet either.
Where did my accumulated BAT go? Is it being held in a different wallet somewhere? Thank you to anyone who can assist me in getting my accumulated BAT back.
Version 1.31.88 Chromium: 95.0.4638.69 (Official Build) (x86_64)
Yes, Gemini wallet
November 4th, 2021
No, this is the first I set up my wallet.
Are you using a VPN? (yes/no)
No
Yes. Minnesota, USA
N/A - Using MacBook Pro
N/A
