Problem with brave ad blocker - Vie Faucet website
the problem is on this page
I get this with the brave ad blocker in standard and in strict
and I can’t claim the rewards
with the brave ad blocker deactivated it does not show up
and if I can claim the rewards
@fanboynz
could you please identify the problem and fix it?
windows 10
brave Nightly last version
@fanboynz could you fix it please
@fanboynz asked if the issue was fixed, back in November 2024
. . . and you replied that the problem was fixed . . . but in December 2024, the issue returned.
You might visit:
brave://settings/content/siteDetails?site=https%3A%2F%2Fviefaucet.com
. . . and examine the settings.
if the problem has been solved 2 times
in November and December
@fanboynz has done a good job
the problem is the same, so fanboynz knows how to fix it.
this is the third time it has happened again
this time it lasted about 4 months approximately no problems
I don’t know what it’s due to, but the problem occurs again after a while.
I wonder if there is a definitive solution?
No, never. They have a lot of rotating ad servers and protections. On top of that they have a lot of anti-adblock scripting in to prevent buttons from working unless windows open or ads are served. A person could go through and generate a ton of filters to fight it for a short period but then it would change up again.
I was trying to mess around on that site, but even uBlock Origin doesn’t work well. Then I spent a couple hours using my very limited knowledge but also random scripts and help from AI but ChatGPT, Grok, and others couldn’t ever figure it out. I mean, made progress here or there, but it’s a pain.
Might be easier for people like Fanboynz who are very knowledgeable and all. But I’m assuming it still is a decent amount of time and effort. And it would always require revisiting and updating things on a pretty regular basis. It just wouldn’t be worth it…especially for such a niche site.
Hi @Saoiray, thanks for trying
when Fanboynz fixes this problem do this…
i found the cause and solution this way:
when Fanboynz fixed it the first time
I was blocking items with brave adblock
in the faucet section of the page, until I left only the captcha and the
the blank page, and if you can claim the rewards with the blank page
here comes a point where this appears if you keep adding the hidden filters in the blank page
and you can no longer claim the rewards.
I don’t remember the name of the filters that I created but when I
removing it from the brave custom filters fixed it
again and I was able to claim rewards
those filters no longer appear in custom filters
so I can’t remove them or whitelist them.
apparently they are in the cloud or something like that
important
it seems that the solution is to put in the custom filters of brave a filter whitelist section
to put these filters in exceptions
If @fanboynz is unable to solve it for Brave Shields, then I know uBlock Origin at least was able to come up with a solution. If you aren’t already using it, go to brave://settings/extensions/v2 and enable the toggle for uBlock Origin.
Once that is done, have the rules below in the My Filters section..
viefaucet.com#@#.ads:style(height:1px !important)
viefaucet.com##.ads:style(position: absolute; opacity: 0; pointer-events: none;)
When I tested, I only had these for Filter lists. I do not know if any others might break it.
If you do this, it should work. Just make sure you have Shields off because otherwise it detects you and would be a problem on that website.
@Hikane yes it works thank you very much
I hope that fanboynz can also solve it for Brave Shields
Thank you very much @fanboynz
Its not me. It comes from uBO. Please stop prodding me.
