Low volume in Brave, works on other browsers perfectly
Description of the issue: When I open youtube and watch a video the volume is really low.
  1. Open YouTube
  2. Search for a video
  3. Open the video and listen to the sound
Expected result: Really low sound from YouTube video
Brave Version( check About Brave): [Version 1.13.82 Chromium: 85.0.4183.83 (Official Build) (64-bit)
Additional Information: Checked volume mixer and Brave is maxed out, still having the prbolem.
Hi @badr, Welcome to Community!
We have a few threads talking about audio output in youtube, can you check them out and see if they solve your issue:
Thank you but the first thread about turning #try-supported-channel-layouts flag on, but I can’t find the flag itself.
Oh sorry, then ignore that one, it looks like it may be a depreciated flag.
Tried every solution, none worked,
@Mattches Can you help?
@badr,
Can you please try creating a new browser profile (Menu --> Create profile) and see if Youtube’s volume still sounds lower than it should when using the new profile?
