Hi new to brave just wondering When on youtube or any site with audio. its so low. pc volume normally sits at 16 -20 volume but in brave i have to go up to 36-40 volume, any ideas?
Thank you for reaching out and I’m sorry to hear you are going through this. Before suggesting a solution, could you kindly use a chromium base browser to see if the issue repeats there?
Thanks for your reply, could you kindly check Settings -> System -> Sound -> Advanced Sound Options -> App volume and device preferences and check to ensure that Brave is not set super low here. Additionally you will have to try playing some sound from the browser before it will appear in that list.
