1.Whenever I am using brave my laptop fan runs like I am playing a game. Either it’s 1 tab or 10 tab same thing is happening. Even after disabling rewards this is happening.
This is not happening in Edge browser or Firefox only brave and I do have only one add-ons IDM(Internet download manager) if u want to use it than I need to reload it.
Anyone experiencing this type of issue?
Any solution for this kind of issue?
Brave Version:
Version 1.22.70 Chromium: 89.0.4389.105 (Official Build) (64-bit)
Hey ,
Try checking Brave settings to see if Hardware acceleration is turned on. It is usually turned on by default. Turn it off and then restart Brave.
well then i guess its the same with me too. cause even on my laptop(which is pretty new) the impact of brave is pretty high. It’s probably cause Brave is a new software and is not very optimized like older browsers like Chrome or edge.
