1.) It was worse before updating windows to the current 24h2 version, but it’s typically happening either within seconds to minutes of opening the browser, or sometimes not for an hour or so. Before 24h2 it was within seconds to minutes all day. After installing 24h2 it may periodically happen during the day, but seems to spike a lot more after 5pm at the moment. I have to keep closing the browser and reopening, and it might happen straight away, after several minutes, maybe an hour. Who knows?
2.) Currently 4 as I switch between the same ones a lot as an author, however before December last year I had maybe 8 or 9 pinned tabs all the time and it was FINE. I rarely had any sort of spike like I’m getting now.
3.) Facebook is a known culprit for this sort of thing, but I moved it to just being a bookmark and closed the pinned tab (again, as an author I use it - for my page), and it still did it. The only ones I have open now are outlook and gmail emails, and a google search page - which I only pinned recently to try to use as a neutral page, hoping the others would be dormant until used. So it still happens whatever I do.
4.) I tried switching off the Adobe Acrobat Reader extension, but it still happens. I use the Norton one (I’d rather not say which for safety reasons publicly) regularly, but it’s not active unless I choose to activate it.
I have run malware scans, including a startup one, and they all come back clear. Norton is a paranoid piece of software, which I don’t really mind as it’s better to be overcautious than lax (as I have experienced AVG and Avast to be). I can run other programs and browsers without issue with this laptop, which has 16gb RAM without issue. It seems to be only Brave that’s doing this. I don’t really want to try to clean reinstall if I can help it, as I have a plethora of bookmarks and this has only been happening since, I think, a recent update. I think it’s only been going on since December 2024.
Granted the resource usage/fan kicking in will also occur when Windows is updating in the background, but I check this in the task manager. When that’s happening, I still close the browser, but most of the time it’s not Windows update. With Brave open, it’s apparently running 16-22 instances (give or take), and if there’s no windows update, the fan calms down and stops once Brave is closed.
