Briefly describe your issue:
So, i have sync my Brave Rewards on my Samsung Phone, (have 66.638 BAT) with Uphold account.
Received around 4 BAT, from 5 payment : 3 payments on Apr 4 (1.25000 twice, plus 0.50 BAT), one on apr 24 (1.25000 BAT), and one on May 11 (0.44000 BAT).
Now, i have these 66.638 BAT on Rewards, but i can’t transfer it to uphold account, so i’m stuck without possibility to use the BAT i earned for months…
Here’s a proof of my Brave Rewards BAT below :
)? It’s version 1.29.81 Chromium: 93.0.4577.82 on Android 11
Is your browser wallet currently verified? (yes/no) Yes with uphold
What date did you verify your wallet? Early April
Have you been able to successfully receive payments in the past? Yes
Are you using a VPN? (yes/no) No
Are you in a supported region (see here for list of supported regions)? Yes (FRA)
“Your SM-G975F PASSED SafetyNet compatibility test” (image below)
Have you manually turned off Auto-contribute on all of your devices linked to Uphold?? Yes, i did.
