Help my missing BATS
Briefly describe your issue:
I verified my uphold wallet and then the funds disappeared and were never transferred. I had over 30 bat in here. wallet was verified around the Jan 29th date. Funds have not arrived.
What Operating System and Brave version are you using ( Menu --> About Brave )?
windows 7 Pro 64Bit -
Version 1.34.81 Chromium: 97.0.4692.99 (Official Build) (64-bit)
yes
Jan 29 2022
into my local brave balance yes. for about a year the Bat have been ading up.
Are you using a VPN? (yes/no)
no
yes
not an android
yes
Adding this in here as this is the first i have seen this info… From my reward internals…
01/29/2022, 01:39:47 PM promotion_claimed 30.250000
01/29/2022, 01:39:45 PM fetch_old_balance 0
01/29/2022, 01:39:45 PM wallet_status_change PENDING ==> VERIFIED
01/29/2022, 01:39:45 PM wallet_verified uphold/e6f38
01/29/2022, 01:39:44 PM wallet_status_change NOT_CONNECTED ==> PENDING
wallet verified, 30.250000 bats missing. (not including the rest of the january Bats)
there is also this on the bottom of my log.
[Feb 13, 2022, 12:09:10.8 AM:ERROR:refill_unblinded_tokens.cc(194)] Failed to get signed tokens
[Feb 13, 2022, 12:09:17.9 AM:ERROR:refill_unblinded_tokens.cc(194)] Failed to get signed tokens
[Feb 13, 2022, 12:11:20.0 AM:ERROR:refill_unblinded_tokens.cc(194)] Failed to get signed tokens
[Feb 13, 2022, 12:14:43.2 AM:ERROR:refill_unblinded_tokens.cc(194)] Failed to get signed tokens
[Feb 13, 2022, 12:23:17.2 AM:ERROR:credentials_promotion.cc(503)] Token list empty
[Feb 13, 2022, 12:23:17.2 AM:ERROR:uphold_wallet.cc(330)] Transferring tokens failed!
They Fixed it! !!! !!! All of the Bats are back and i can has ADS again! Thank you Brave.
