Need help with missing BATs
I transfer 2.5 BATs from my iPhone to my desktop Brave wallet. It worked. Then I clicked on “Withdraw Funds” thinking it would transfer to my Uphold wallet. The BATs disappeared from the Brave wallet but hasn’t shown up in my Uphold wallet. So, where did they go?
Also, I seem to be having the same problem as many others, and last months BAT rewards has been “pending” for weeks now.
I’m on Mac OS 10.12.3, using Brave browser 1.24.85.
Yes.
2-3 months ago.
Yes.
Are you using a VPN? (yes/no)
No.
Yes.
I’m on a Mac desktop.
No.
Thank you in advance for your help.
