Please ensure that you’ve read through the following topics/pages thoroughly before opening a topic as your question may have already been answered:
Hi , i cant connect uphold with mobile and pc device coming wrong area problem but im still in Uk so no idea why pls help anybody witgh 1 deciced i cant connect a long time thx a lot
Briefly describe your issue:
Are you using a VPN? (yes/no)
Have you ever had a passport or other document from a different country?
Issue that has been occurring with a lot of people is a mismatch between KYC. Uphold sometimes can be content with just updating the mailing address and submitting those documents, but Brave isn’t. What happens is the API communicates between Uphold and Brave about your information. The crazy part is Brave staff can’t access it, but the system does.
So what could be happening is it’s seeing your prior passport for whatever country you were in and it’s telling you it’s an unsupported region based on that. Unless/until that’s updated between their systems, you’ll likely have this problem.
Part of the reason for it is because it’s an extra layer of fraud protection. It’s easy to fake a mailing address but harder to get official government licenses/passport.
thx for answer , but i hacent problem before , i use brave long time , then start problem with connect 1 decise so connect another being not a problem just when i back from holiday coming wrong area and cant connect device
And I asked you a question, if you’ve ever had a passport from anywhere other than the UK? Not sure why you’re not answering. It’s kind of an important question.
A lot of people who say as you are end up revealing they were originally from India or some other country which Brave does not support at this time. If the passport is from one of those countries, then you’ll not be supported until you update to UK identification.
