Brave Rewards not received for July. May and June no problem receiving with my Gemini Wallet but July has
Briefly describe your issue:
Did not receive June Brave BAT rewards - no button to claim in browser for July. I earned 7+ BAT in July but was unable to claim as I have not seen the “Claim button” for July like I did for May and June.
MAC OS | Nearly up to date! Relaunch Brave to finish updating.
Brave Version 1.41.100 Chromium: 103.0.5060.134 (Official Build) (x86_64)
Yes
Mar 17, 2022
Yes for May and June.
Are you using a VPN? (yes/no)
No
Yes. US
Hi. For the August payout, you need to update your system to the latest version (1.42.88). There was a payout issue which has since been fixed. See the notice linked below.
Payouts are still processing. After updating, you should wait for payouts to finish processing to see if you receive claim buttons . You can check payout status at Brave Ads Payout status or at Regional Catalog Viewer . If you do not receive your payout for August (or previous months), then submit a request for support to investigate all the months with payout issues using the form linked below.
