http://www.smarter.yt extension “SmartVideo for Youtube” is causing a problem, dropped graphics and fonts.
I dont know if its their problem or not. It also happens in Chrome, so it’s likely a Chromium issue (or plug in) versus Brave. Your call if you take this any further, feel free to close it.
Any youtube videos (this one for example: https://www.youtube.com/watch?v=CI7tXnxfXzU)
Not this - uninstall the extension and its gone
everytime
page in the main menu):
MacOS High sierra
Can you try disabling Hardware Acceleration
in settings to see if this resolves the issue?
Last updated: 3 June 2014
I can imagine this could be buggy, 6 years without a update and Youtube has changed plenty. Is there a certain function you’re wanting from this extension @cswanson ?
So yeah, I just randomly found that extension, did little research, and the web site doesnt look much updated - I’ve already removed it.
@fanboynz you asked what function I needed, so maybe you can advise me? I wanted youtube videos to pre-load when I CMD-clicked them to open in a new tab - so I didnt have to continually wait when I switched over to it.
@Mattches - you asked: Can you try disabling Hardware Acceleration
in settings to see if this resolves the issue? => I did that and it actually solved the problem, so good question on that.
So again, @fanboynz is right, if it’s old and out-of-date, then feel free to ignore this, I’ve removed the extension and I’m all good.
Thanks!
