Did the issue present with [default Shields settings]
No.
Shields seems not to break anything on the site. Only dice rolling is broken irrespective of Shields being up or not.
No.
I do not have Chrome installed, but I would hazard a guess that it does.
Ubuntu 20.04.3 LTS
Version 1.31.91 Chromium: 95.0.4638.69 (Official Build) (64-bit)
The only extension I have running is GNOME Shell Integration to stop the OSK from popping up every time I click a text box. I disabled it and refreshed the page. It still isn’t working. There’s a little sad face in the top left.
If you create a character you can roll dice by clicking on some of the boxes.
I have turned Shields on and off with no change.
I opened the page in Firefox and was able to roll dice normally. Brave Private browsing doesn’t seem to help. I still get the little sad face in the corner and no rolled dice.
Installed Chrome just to see if it would work. On a fresh install I have the same issue. Little face in the corner and can’t roll any dice by clicking on the boxes.
Clearing cache/cookies didn’t seem to help either.
I had already posted there before I came here, hoping it was an issue they could look into, but I got no replies. Granted it’s only been a couple weeks.
