Error: Country mismatch
Hmm, it looks like the Brave Rewards country you are in does not match the country of the Uphold account you are trying to connect to.
But uphold supporting the Turkey right ? (I used my driver license on Turkey and That was supported choice)
How can I solve this problem ?
Changed the topic to the more appropriate one. Also do note, brave rewards is different from the brave wallet.
So, did you choose another region than Turkey when it asked you to select region in brave rewards ?
if yes, then you’ll have to reset Brave rewards. That will cause you to lose the rewards earned. You should choose the region which you used documents from for KYC / AML.
