Verified wallet - Balance not transferring
Thank you for the prompt reply, yes it was.
Hi Steeven,
After replying to your email, I noticed I received a bunch of emails from Brave, confirming transfers to my account, with the correct amount.
Sorry to have bothered you, I guess there is a delay with the synchronization of accounts.
I have two more technical problems with the browser, can I impose on you with them?
warmest regards,
Berj
I have replied to your DM. Pls check.
woa, how did you earn so much BAT? BTW Iā€™m having the same problem, BAT not transferring to UPhold since Nov
as you can see with Twitch and Youtube Channel.
Hi @RJK1776 - great to hear!
@Abhi3025 - working through my DMā€™s now. Thanks for your patience.
Hi @steeven - still not having any luck with mine either, it also seems the ā€˜wallet verifiedā€™ has disappeared too
Thanks for following up @DephektDNB, just replied to your DM.
Yes, I have the same problem, @steeven 2 weeks ago I sent dm but got no results
I am also running into the same issue- I sent @steeven a DM with the details.
Also-- Thanks for your hard work, Iā€™m looking forward to speaking with you! I hope we can fix this soon.
Is there any update on this front? I sent a DM and a follow-up a while back but have yet to hear from you all.
I heard from @steeven and he said that the BAT should transfer automatically without needing to ā€˜claimā€™ the BAT. Disconnecting the wallet and verifying again hasnā€™t helped, so Iā€™m hoping a manual transfer on his end may be a possibility.Still no progress as to WHY this isnā€™t happening automatically with a verified wallet, hope this helps
hey @steeven i already dm you. could you please check out my message too. thx
Payments are still processing. Please follow this post for updates - March 2021 Brave Ads Payout Status. If you havenā€™t received by Monday, please follow the steps in the post for reaching out. Thanks!
