- What is the difference in settings in the default cryptocurrency wallet between “Brave Wallet” and "Brave Wallet ( Prefer Extensions)? Why would I use one over the other? What is the default?
Default cryptocurrency wallet - Use this option to set the default wallet the browser will use when interacting with dApps while browsing:
Brave Wallet (Prefer extensions) - Select this option if you have a Brave Wallet created, but want sites to default to using a different wallet extension, such as MetaMask for dApps.
Brave Wallet - Select this option if you want dApps to use your created Brave Wallet.
Crypto Wallets (deprecated) - Select this option if you elected to use the old Crypto wallets setup rather than the new Brave Wallet implementation. Depending on your installation, you may not see this option.
None - Select this option if you do not want sites/dApps to interact with any installed or created wallets.
Source: How do I manage crypto assets in Brave Wallet?
Hope this helps!
