Hello, i am having a problem remembering logged in accounts on Brave. When i log in to my account, for example on YouTube, and Turn off brave, and when i Turn IT on, It logs me out and it worka normalny on other browsers
Maybe someone know what to do please
I could guess it has something to do with your cookies being cleared when you close your app.
It’s not a bad idea to have your cookies cleared each time you close the app but obviously annoying for the times you want to have your cookies saved for certain sites, so I might suggest.
On the sites you want to keep from being cleared:
- Click the Brave logo icon on the right of the address bar, and UNcheck “Forget me when I close this site”
- Click the settings icon on the LEFT of the address bar, go to “Cookies and site data” then “Manage on-device site data” click the three lines (the hamburger or sandwich menu as some call it) and then “Allow to save data”
Make those changes on one or two or all of your login websites, close and open the app and see if that works.
however, logging out started repeating, maybe someone can help??
unfortunately it didn’t help, you can ask for more advice to fix it, it’s very annoying
If anyone wants, I can provide more information
When you are here:
and on the “On Exit” Subcategory
Do you have “Cookies and other site data”
Checked to be deleted and saved?
OR
When you are here:
brave://settings/content/siteData
Do you have either of these two options chosen:
(NOT the first one, not if “Allow” is selected, if it’s that one is selected that should be ok).
Delete data sites have saved to your device when you close all windows
Sites will probably work as you expect but won’t remember you after you close all Brave windows
Don’t allow sites to save data on your device (not recommended)
Sites may not work as you would expect. Choose this option if you don’t want to leave information on your device about sites you visit.
OR again when you are here:
brave://settings/shields
You have this TURNED OFF?:
(Clears cookies and other site data when you close a site.)
the first option helped me, I don’t know why I had it selected, thank you very much for your help and best regards
