Private window TOR tab problem
sriram, I have tried this but no joy. I also looked in the Tor folder that Brave creates and there is no sign of any data file having ever being created. I think that this is because I am not ever being connected to the Tor network so the data file is not generated.
Could you check the Tor.log under %appdata%\brave\tor\data\? Does the log say `Bootstrap 100%: Done? Or does it show any error message in the log?
I have used EasyFfnd for the Mac and the Tor.log is not present nor is %appdata%\brave\tor\data
As I said earlier the data file is not being created. The Data folder and the Watch folder are both empty.
I am having similar problems trying to connect to Tor network within private tab on Brave for Mac.
I am also using El Capitan Mac OS 10.11 but am not using VPN and the log files are empty.
I did get some info from Terminal when starting up Brave from the Terminal App as suggested in this thread and interestingly I got this error:
dyld: Symbol not found: _getentropy
Referenced from: /Applications/Brave.app/Contents/Resources/extensions/bin/tor (which was built for Mac OS X 10.13)
also:
[2158:20483:0703/002512.669737:ERROR:tor_launcher_impl.cc(218)] tor got terminated by signal 5
[2151:1295:0703/002512.756102:ERROR:tor_launcher_factory.cc(105)] Tor Process(2159) Crashed
This i think is indicating that the tor code was written for Mac OS 10.13 and above and may not be compatible with older versions of Mac OS such as 10.11 El Capitan.
I would like some confirmation from the Brave team if this is correct.
Thanks.
Ok so i was trying to connect through tor using Brave but I can’t connect. I read through the post and I saw something about a tor.exe file. I actually looked it up and I started it and I recieved this:
Jul 03 10:18:48.182 [notice] Tor 0.3.3.7 (git-035a35178c92da94) running on Windows 8 with Libevent 2.1.8-stable, OpenSSL 1.0.2o, Zlib 1.2.11, Liblzma N/A, and Libzstd N/A. Jul 03 10:18:48.186 [notice] Tor can't help you if you use it wrong! Learn how to be safe at https://www.torproject.org/download/download#warning Jul 03 10:18:48.215 [notice] Configuration file "C:\Users\TheWinner\AppData\Roaming\tor\torrc" not present, using reasonable defaults. Jul 03 10:18:48.220 [warn] Path for GeoIPFile (<default>) is relative and will resolve to C:\Users\TheWinner\AppData\Local\Brave\app-0.23.19\resources\extensions\bin\<default>. Is this what you wanted? Jul 03 10:18:48.220 [warn] Path for GeoIPv6File (<default>) is relative and will resolve to C:\Users\TheWinner\AppData\Local\Brave\app-0.23.19\resources\extensions\bin\<default>. Is this what you wanted? Jul 03 10:18:48.223 [notice] Scheduler type KISTLite has been enabled. Jul 03 10:18:48.223 [notice] Opening Socks listener on 127.0.0.1:9050 Jul 03 10:18:49.000 [notice] Bootstrapped 0%: Starting Jul 03 10:18:49.000 [notice] Starting with guard context "default" Jul 03 10:18:49.000 [notice] Bootstrapped 5%: Connecting to directory server Jul 03 10:18:49.000 [notice] Bootstrapped 10%: Finishing handshake with directory server Jul 03 10:19:20.000 [warn] Problem bootstrapping. Stuck at 10%: Finishing handshake with directory server. (DONE; DONE; count 10; recommendation warn; host E480D577F58E782A5BC4FA6F49A6650E9389302F at 199.249.223.43:443) Jul 03 10:19:20.000 [warn] 10 connections have failed: Jul 03 10:19:20.000 [warn] 10 connections died in state handshaking (TLS) with SSL state SSLv2/v3 read server hello A in HANDSHAKE Jul 03 10:19:37.000 [warn] Problem bootstrapping. Stuck at 10%: Finishing handshake with directory server. (DONE; DONE; count 11; recommendation warn; host BD6A829255CB08E66FBE7D3748363586E46B3810 at 171.25.193.9:80) Jul 03 10:19:37.000 [warn] 11 connections have failed: Jul 03 10:19:37.000 [warn] 11 connections died in state handshaking (TLS) with SSL state SSLv2/v3 read server hello A in HANDSHAKE Jul 03 10:19:44.000 [warn] Problem bootstrapping. Stuck at 10%: Finishing handshake with directory server. (DONE; DONE; count 12; recommendation warn; host A0F06C2FADF88D3A39AA3072B406F09D7095AC9E at 46.165.230.5:443) Jul 03 10:19:44.000 [warn] 12 connections have failed: Jul 03 10:19:44.000 [warn] 12 connections died in state handshaking (TLS) with SSL state SSLv2/v3 read server hello A in HANDSHAKE
Can someone help me?
PS: If there is a problem of the long log, please tell me so that i can paste it in pastebin
We don’t seem to be getting much input from the Brave team on this issue. Is there some other area where this question will draw their full attention where we can get help with this please?
Well it is only in beta and i’m sure the team are aware of some issues like this, maybe we just need to wait patiently for an update that increases compatibility with older OS’s if that is indeed the problem we are experiencing.
You can follow the teams progress on pending issues with Tor and others over at Github. https://github.com/brave/browser-laptop/issues
@Verita If tor is unable to start on macOS, that may be a symptom of https://github.com/brave/tor_build_scripts/issues/18 which we’re looking into. This appears to be the case of @dogcow’s problem.
@thewinner958 Your problem is a little different. It appears that we are unable to reach the Tor network. It is possible that you are on a censored network. Just to double-check, can you confirm: (a) whether you can browse the web in Brave without Tor, and (b) whether the Tor Browser works on your network?
Thanks, looks like you’re ontop of the issue.
Thanks for this update taylor, much appreciated knowing that it is being investigated by the team.
@taylor Well the browser works fine if I am not in the Tor network on Private Tab and I did had problems with the Tor Browser not connecting to the Tor network at all which I needed to use a tunnel and the same problem happened in OnionShare which I needed to change the settings so that it could use the Tor Browser’s configuration.
@thewinner958 OK. It sounds like your network blocks access to the Tor network, then, so you will need a bridge or some pluggable transport to reach the Tor network. We have an issue to track this, but unfortunately we probably won’t be able to add this feature for another couple months: https://github.com/brave/browser-laptop/issues/12989
Update: Thanks guys, (@taylor) the latest Brave Update |Brave|0.23.39|V8|6.7.288.46| has fixed the issue for me, now have Tor Browser tab working great on my older Mac. Good job!
Well done guys this latest update to the browser has corrected my previous non connection to the Tor Network issues. Many thanks to all involved for the help given.
Cannot use private tab with Tor browser it crashes every time, version 23.79. Thanks.
Cannot log into ISP provider either thank goodness for Firefox with enabled cookies works. what else needs to be done.
