After installing MACOS 15 (Sequoia, Brave consumes over 200% CPU energy. Actually causes the case to heat up. Not an issue on Sonoma. Hoep uou can fix. Switching to Safari – less than 5%.
system
Closed
2
Related topics
Serious power drain on macOS Sequoia. MacBook Pro 48GB M3 max. Brave consumes 20-30% of CPU cycles.....creates serious heat generation....compare with Safari at less than 5%.....I LOVE Brave....please fix | 1 | 496 | October 20, 2024 | |
Power consumption on macOS | 4 | 210 | January 1, 2025 | |
Energy Consumption by Brave | 0 | 1155 | October 23, 2019 | |
Better Heat & Power Management on macOS | 0 | 629 | April 22, 2019 | |
Brave using a significant amount of energy (Mac) | 4 | 3750 | December 11, 2019 | |
Brave Browser uses 62 average energy consumption on Macbook Pro with touchbar | 1 | 1179 | December 16, 2019 | |
Brave using significant amounts of energy after update (Mac) | 3 | 809 | April 1, 2023 | |
Brave using 'significant energy' | 2 | 460 | March 24, 2024 |
