Not able to claim rewards for unverified instance for unlocked device
I am using android without google play services so my device is not approved by safetynet. So whenever i am trying to claim my rewards, error is occuring that “something went wrong”. Now i looked into rewards logs and found out that it is because of safteynet. I am attaching the screenshot of logs
If you are using custom rom without google play services
If your bootloader is unlocked
Rewards should be claimed.
1.38.109 Chromium: 101.0.4951.41 (Official Build) (64-bit)
Mobile Device details
Android 12.1 based on AOSP
@pranavvaid it would be nice if you would have filled out everything as it shows when you go to create a topic. I think you answered your own problem to an extent.
That question was part of the template they have when you create a new Topic, especially under Brave Reward generally, at least if you had properly put it under Rewards Support. You’d have seen everything below (and would have been asked to check and answer it all)
In any case, your device likely would fail SafetyNet. Rewards can’t be claimed if you’re not able to pass SafetyNet.
Please ensure that you’ve read through the following topics/pages thoroughly before opening a topic as your question may have already been answered:
Briefly describe your issue:
Are you using a VPN? (yes/no)
Also, another official answer for you:
Okay, clears things up. I am sorry, but i know this issue is persistent on github and here.
I just wanted to know if there is a roadmap to drop safetynet and use some other method like desktop’s captcha.?
Because if no, then Brave should not advertise it as a privacy friendly browser as it is doing heavily now, when still using Google’s binaries and API’s on devices, which BTW is only possible on 1/3rd of their device share.
Not to my knowledge. The person who would best answer that would be @Serg who is on the Android development team. Either that or perhaps @Mattches or @SaltyBanana if they end up having time to advise.
At this time there is not a road map/plan to do so that I’m aware of. If we do come to this decision, we will certainly inform the community of the changes.
