Hello
I’m not able to get verified for https://rave-on.shop
I’ve add the TXT on the DNS server. Wait for some weeks now.
I want to run ads and so on…
Hello
Hi there. I checked rave-on.shop on Google DNS lookup and it does not appear that the TXT record was correctly added. This must be a public DNS TXT record.
As you can see, the token identifier record doesn’t appear to be visible…
Hello Asad,
thanks for ya reply…
OK, I don’t know… I just use shopify and added the TXT to the other…
What should I do??
Look at the screenshot please
Hi there, make sure you paste the FULL TEXT that the verification wizard displays into your new DNS entry, not just the exact value of the token itself
