I’ve been setting up shortcuts for brave and was successful with the “open tab in new window,” but when I tried to set “maximize window,” the keybind never maximizes the window nor does it do anything I can notice. I was thinking maybe I’m misunderstanding what that shortcut should do so maybe that’s the issue, I assumed the shortcut would act like hitting the square in the top right when the page is not full size. I tried a few keybinds for it, “ctrl + arrow key up” as well as numpad + but neither worked. Same issue with minimize window, again i did “ctrl + arrow key down” and no luck.
- Set the “maximize window” shortcut in the settings
- Nothing happens when activating the shortcut
Seemingly nothing happens
The window should maximize to the full monitor display size
Everytime i try and set the shortcut/use it. Ive tried on two different profiles as well and neither works.
page in the main menu):
Windows 10
Version 1.61.116 Chromium: 120.0.6099.217 (Official Build) (64-bit)
