Hello,
I have the following problem with Brave browser I copy a webpage address from Edge, but when I try to paste the webpage address into Brave nothing happens.
Any help would be great.
Thanks
Matthew
Hi @matthewatlant0s,
Can you confirm if you’re on Windows 10 and what version of Brave you’re on (brave://settings/help)?
Also, can you tell me how you’re copying the link? i.e. are you using the keyboard shortcut (Ctrl+C / Ctrl+V) or are you right-clicking then copying?
Also also, are you able to paste the link into other applications?
Hello,
I am running windows 8.1 and the version of brave is [
Version 1.22.49 Chromium: 89.0.4389.72 (Official Build) beta (64-bit)
I right click the web address and click copy in Edge and then open Brave and right click in the web address bar and left click paste but nothing happens.
Do the same in Brave and it works.
Hope this help.
Thanks
Do you have any extensions installed?
Does using Ctrl+C / Ctrl+V work?
Hello,
I am happy to tell you that the problem is now fixed,
I copy a webpage address from Edge and opened Brave click in the address bar click paste and it worked.
Don’t know if there was a problem with Edge but I sent the problem in by feedback to Edge, after the latest update for Edge the problem looks like it has been fixed.
Thanks for all your help.
Matthew
@matthewatlant0s,
Glad to hear it was resolved!
