My gmail open in brave have problems while when opened at chrome is ok. The problems are google hangouts is signed out and a red stripe appear time after time telling: Gmail is having authentication problems. Some features may not work. Try logging in to fix the problem.
i know you expert but just in case you missed something
make sure that hangout extension enabled here brave://settings/extensions
did you check it on private mode
a) if private mode work then maybe the issue with one of your extension so try to disable all of them and if it work then re enable them back one by one til you get the one that cause the issue
b) if extension was not the issue then try to clear the cache and cookies
if all does not work then start brave using this flag --user-data-dir
Thanks for the answer. I am not an expert and my post wanted to let know to the staff of the brave the above problems.
You are right. The hangout extension was not enabled at brave settings. I enabled that but the problem persist. The situation is the same. As for the other solutions I prefer to not do nothing. Don’t worth to disable all extensions (I have to many). But first of all could be created other problems. I am not an tech or computer expert.
Even this would help I don’t see the solution. I want to use brave browser without having such kind of artifices. I haven’t use private mode never and don’t know how to use. I am not interested to use the browser in private mode so I need the solution in normal mode.
Thanks again @justsomeone1 I solved my problem. No need to open gmail at private window or to make other things. It was enough to sign in again and everything work perfectly.
Remain then the problem at my Facebook in which are missing contacts (all the right column of the page of Facebook).
