**After updating to version 1.68.128 of brave-browser on my Ubuntu, I started having problems with JS being disabled by default on all sites, after a lot of inconvenience, I decided to go to settings/shields and disable the “Block Scripts” option, but this option is still enabled on sites after that. *
For example, if you go to a site like X/Twitter, you get the message JavaScript is not available.
If you go to brave/settings/shield and deactivate the “Block Scripts” option, and then go to the X page and reload it, you will see in Shields that the Block Scripts option is still activated, can you help me solve this problem?
Thank you.
