Please solve this problem.
Error: Device limit reached
Your Brave Rewards cannot be verified because you’ve reached the maximum verified device limit.
Hi,
You have reached the maximum number of verified devices allowed. i.e. 4.
Either you linked too many devices to this account, or you made the same mistake as me, reformatting your PC too often. Yes it’s ridiculous but it counts in the maximum.
No solutions for months. But they say they are working on a solution.
you may have less information than what I just gave you in the following links.
See you
Thank you, Sir, but what else I can do it? What will happen with my BAT? it all will be goes to zero?
Your BAT’s will continue to be stored on your browser until you can do something with them, or eventually use them to self-contribute. (or that you reformat, in which case all will be lost)
There’s a kind of trick that can allow you to self-contribute yourself by linking a twitter account to an uphold account, something like that, but it seems like an indescribable difficulty.
For my part, I am in the same case as you, I wait.
You can use this to reset 1 device. Unable to re-verify wallet - #118 by Mattches . In addition, Brave is supposed to be eventually coming out with a way for us users to remove the devices but it is being worked on and not sure when it will be available.
@Radhe9898 I just created a new topic on it. Try to check it out at Notice to all: device limit
@HighPriestess42 just tagging you too so you can check it out for update shared today on the status and all.
