Dark mode problems
I enabled Dark Mode and some web pages don’t display a lot of their headers/titles/labels. I think maybe they’re white font on a white background. If I select the entire page (Ctlr-A on Windows) the labels are all visible.
I disabled Dark Mode in the browser but it didn’t disable entirely as compared to Chrome or other browsers not using dark mode so even in standard/light mode setting some of these pages still can’t be viewed correctly.
One example page for this is Gmail. Many of the labels in Gmail aren’t displaying - I can’t see my folder names or the header for the folder list.
I uninstalled and re-installed Brave and it made no difference.
Go to brave://flags
Search dark
Disable both options/flags
