Two weeks ago, a problem started when I needed to mark work with CTRL+Shift+RightArrow.
**How can this issue be reproduced? **
- open the browser and place the marker near a word
- try to select a word with CTRL+Shift+RightArrow
2.1 even in the address bar, I can’t select the word to the right. - Try again with CTRL+Shift+LefttArrow
**Expected result: **
The word should be marked to be copied.
**Brave Version (check About Brave
1.62.162
**Additional Information: **
The problem was encountered only under Brave two weeks ago.
