Captcha problems
Briefly describe your issue:
After cycling turning on Brave Rewards to prompt the captcha, I’m getting a grant.rewards.brave.com error under my Rewards icon (next to Brave Shields icon) and am not receiving any ads.
Version 1.45.131 Chromium: 107.0.5304.110 (Official Build)
Linux
Is your Brave Rewards Profile currently verified? (yes/no)
Yes
What date did you connect a your Brave Rewards Profile?
Yes
Are you using a VPN? (yes/no)
No
Yes
N/A
Have you manually turned off Auto-contribute on all of your devices?
Yes
@SaltyBanana please take a look.
Hi @celeborne welcome to Community :wave:
Our team is looking into the issue.
