Hi!
Description of the issue: When using Brave Browser, in particular when reproducing videos onYouTube or using a site with 3D features the laptop gets incredibly hot to the point that it crashes.
In the screenshot you can see the high power consumption and temperature.
Using a browser like Edge doesn’t cause any of these problem even reproducing videos at a much higher resolution.
I have a Macbook Pro 13 (Year 2017 Model A1708) and I have these problem both on Windows partition (Bootcamp) and MacOS partition.
This problem started to appear about a year ago but I realized that brave was causing it just few days ago.
- Play a YouTube video at 1080p.
High load on CPU causing high power consumption.
): v 1.67.123 (same goes for Brave Beta)
-Already reseted the setting, cleared the cache, removed all extensions, turned on Energy Saver and turned off graphics acceleration;
-The computer was even formatted during this period;
- All drives are up to date;
- Problem show on both Windows and MacOS partition.
Curiosity:
The strange thing is that using other high power consumption apps, like photoshop or apps for editing videos doesn’t make the cpu so hot even if the load goes to 100%.
Hope the developer can address the issue.
