I have over 25 bat in uphold. I can log into uphold on the browser on phone. I turn shields off, I leave them on. I click verify, it always says I need 25 BAT or more to verify. It is fine on my desktop pc’s. I have them all in the sync chain.
It will never recognize on the phone. I tried the brave android and the beta.
I reset the brave rewards on the phone.
I uninstalled the beta and the normal Brave browser on phone.
Redownloaded from google play.
made sure the first website I went to was uphold.
Turned shields off.
After in, went to the “?” icon for brave rewards, got past the “got it” pop up. Went to verify…
No good.
Nothing works here to get it to verify. . . . . . .
install brave browser on phone.
go to uphold.
try to verify wallet
Keeps stating I need 25 BAT to do this
Should verify wallet just as it does on PC’s
100% of the time it fails every time.
page in the main menu):
Brave 1.19.86, Chromium 88.0.4324.96
Android 10; SM-A115U Build/QP1A.190711.020
. . . . and I loaded uphold in desktop view just to see if that was any different. tried to verify. still says I need 25 BAT.
I give up.
