If Brave is running, I can’t use my Macbook Pro’s media keys for controlling Spotify anymore. If I kill Brave, they work, if I restart it, they don’t.
I found that the solution to the problem should be to disable the #hardware-media-key-handling flag - but I did that, and it still doesn’t work.
- Start a song on Spotify
- Start Brave
- Go to brave://flags
- Look for the Hardware Media Key Handling flag
- Set to Disabled
- Restart Brave
- Press the Play/Pause HW media key on the Macbook Pro keyboard
Nothing happens
Spotify would pause the playback
80%
page in the main menu):
Macbook Pro (late-2013)
macOS High Sierra 10.13.6
Brave version Version 0.65.118 Chromium: 75.0.3770.80 (Official Build) (64-bit)
Right after having written this post, the HW keys did work. So I’d say that the bug isn’t 100% reproducible.
Here’s my HW info just in case:
Model Name: | MacBook Pro |
Model Identifier: | MacBookPro11,3 |
Processor Name: | Intel Core i7 |
Processor Speed: | 2.3 GHz |
Number of Processors: | 1 |
Total Number of Cores: | 4 |
L2 Cache (per Core): | 256 KB |
L3 Cache: | 6 MB |
Memory: | 16 GB |
Boot ROM Version: | 153.0.0.0.0 |
SMC Version (system): | 2.19f12 |
