The flag for enabling/disabling the media keys from being used from Brave disappeared from brave://flags.
I have found a reddit post which explains a workaround for this problem, which is enabling another flag that make other ones avaiable.
SImply while playing a video from Youtube or other streaming services, press the play/pause button on your keyboard. If you want to change the behaviour of the media keys, you would normally find the option on the flags page, but that flag disappeared.
Version : 1.38.109 Chromium: 101.0.4951.41 (Official Build) (64 bit)
I did not find a proper section to post this, so I chose the place where I think most of the people would ask about the same problem.
Is this an imminent change in the newer version of Chromium APIs? Will we get a proper option to easily switch this function ?
