Hi,
I believe Iām experiencing the same issue.
I installed Brave on Windows 10 in September 2020 (Iām not sure which version that corresponds to). Iāve been installing any updates to Brave since then and Iām now on version 1.17.73 Chromium 87.0.4280.67 (Official Build) (64-bit)
Auto-Contribute is enabled and all the sites in the Auto-Contribute have a blue circled tick. Iāve never used Token Grants, Monthly Contributions, or One-time Tips.
I donāt remember why, but the rewards-internals shows that I did briefly toggle off Auto-Contribute on 28th Sept at least I think thatās what the following log messages indicate:
28/09/2020, 12:24:59 ac.enabled 1
28/09/2020, 12:24:52 ac.enabled 0
24/09/2020, 08:26:31 ac.enabled 1
Looking through my Monthly Statements I can see that Iāve received Earnings from Ads for October and November.
However, Iām also seeing zero for Auto-Contribute in the Monthly Statements which is where I expected my BAT Rewards to be going. The other fields (One-time Tips etc.) are zero as expected.
brave://rewards-internals shows that both months are stuck in āStep: Prepareā and the āRetry Countā is steadily incrementing.
Is it possible to confirm that any sites listed in rewards-internals with a non-zero āContributed amountā are actually receiving the BAT? If they have been then I think it should be reported at a more user-friendly level in the Monthly Statements instead of just showing zero. As it stands the Monthly Statements make it look like the Rewards BAT has vanished.
Do you have a link to the Github issue you raised? Iād be quite keen to follow any technical information and code patches relevant to this issue.
This is my first time on the Community boards, so Iām going to attempt to attach some screenshots of my Monthly Statements and corresponding rewards-internals.
November statement:
November rewards-internals:
October rewards-internals:
rewards-internals event log:
