**Briefly describe your issue:**I had been using Brave for months with no wallet verified or connected and accumulated roughly 17 BAT. realized I could link my Gemini wallet. Upon linking my Gemini wallet, my BAT balance within the browser was reset back to 0.475 BAT. Not sure what is going on
**What Operating System and Brave version are you using (Menu --> About Brave
)?**windows 11
**Is your browser wallet currently verified? (yes/no)**yes
**What date did you verify your wallet?**2/10/2022
**Have you been able to successfully receive payments in the past?**yes
**Are you using a VPN? (yes/no)**no
**Are you in a supported region (see here for list of supported regions)?**US
**Have you manually turned off Auto-contribute on all of your devices linked to Uphold??**no
