Adding manually to top sites does not work
Hi there, I use brave for a while having firefox before and I miss the function of simply dragging sites in the bar. Top sites might be just as good but I cannot manually add sites, my browser does not show the add site function!
Another thing I really miss is a simple screenshot and marker tool
Thank you ! Nicola
Did you mean this thing ?
Screenshot_253
or this thing
the second! Thank you !
@mountainherbs
Am I missing something?
where do I find that customize dashboard? I could not find it.
Look at the screenshot of @rethanis
There is an option below the right corner of the Home tab.
Customize one!
@mountainherbs
New tab pageCustomize.
Make sure you have configured New tab page showsDashboard. You can configure that when you open brave://settings/newTab via the address bar.
sorry, for the late reply! I did everything and it’s still not working…
Can you send a screenshot of that page so that I can see what you have done?
Thanks
