When I navigate to wsj.com with shields up it won’t load correctly unless I disable script blocking. But when I disable script blocking it will show ads.
Screenshot of the ad as it appears in Brave Did the issue present with default Shields settings? (yes/no)
@jtsillas First off, script blocking will break majority of sites because this will prevent most videos and images, which run as scripts. Not to mention things like Java and all. So the report on this makes sense. You want to avoid Block Scripts typically, only enabling on sites as necessary
You should try to check out the filters. Sounds like you’re using just the default. If you to go Settings → Brave Shields → Content Filtering you’ll see a lot of thing you can enable. Try the following:
Fanboy Annoyance’s List
uBlock Annoyances List
Bypass Paywalls Clean Filters
Beyond that, your Shields settings should mostly look like below:
