Hello i dont have received the payment from the last month at my UpHold wallet at brave rewards it shows the ammount of it but nothing at Uphold is that normal ? Is been like that for like 2/3 months not receiving rewards hope someone can help me thank you guys
Yes only 1 browser Like i say 1st 2 months ir worked
So any solution or not ?
@Lordwolfx,
Can you confirm for me that the missing funds were all earned by viewing Brave approved ads?
The problem can be solved now ? or need other screenshots ?
Hi @Lordwolfx - can you try disconnecting and reconnecting your wallet?
What Brave version are you currently using?
Thanks in advance!
I’ve disconnected and reconnected and still the same the version i am using is that one: Version 1.10.93 Chromium: 83.0.4103.106 (Official Build) (64-bit)
I turned my auto contributor off you think is because of that i dont receive the funds at Uphold ? Thanks
Had you enabled it before?
Ya before it was enabled you think is that ?
