HI, does anyone can help me to withdraw my BAT from my browser ?
Hi Samoel, If you provide more information, someone might be able to help.
The template with instructions for requesting support help in the Rewards Support sub-category are on the right side pane of the editor when you create a new topic. If you provide as much information as possible, you are more likely to get help. I copied/pasted the information below for you.
Please ensure that you’ve read through the following topics/pages thoroughly before opening a topic as your question may have already been answered:
- How do I opt into Brave Ads?
- Why am I not seeing Brave Ads?
- Windows 10 Ads Troubleshooting
- Rewards FAQ
Briefly describe your issue:
What Operating System and Brave version are you using ( Menu --> About Brave
Are you using a VPN? (yes/no)
