I have had a problem since June 8, 2022. Everything stopped, my rewards have not been received, the ads are showing but not being charged. The browser has updated 2 times since then and nothing has changed.
Please ensure that you’ve read through the following topics/pages thoroughly before opening a topic as your question may have already been answered:
- How do I opt into Brave Ads?
- Why am I not seeing Brave Ads?
- Windows 10 Ads Troubleshooting
- Rewards FAQ
Briefly describe your issue:
Are you using a VPN? (yes/no)
