Why does Brave still prevent audio from playing through bluetooth
Bluetooth headphones work perfectly under every scenario EXCEPT if the audio or video is accessed with the Brave browser.
  1. Connect bluetooth headphones and test them in the sound settings.
  2. Open any browser other than Brave and navigate to youtube or anywhere else (i.e.) pandora. And enjoy your sound coming over your bluetooth headphones.
  3. Open Brave and go to the same site you were just listening to so raptly. You will immediately notice that the sound is coming out of your system speakers instead of your headphones.
  4. Go to the sound settings. You will see that the sound is still set to play from your bluetooth headset.
  5. Test the headset speakers from the sound settings, and it will play the sounds over your left and right ear just as it is supposed to.
  6. HOWEVER, if you are on Zorin (or Ubuntu probably) you will also see just above Output – in the volume section – that you now have a new volume slider for Brave (in addition to the System Sounds slider that was always there). In fact, if you try to play a second video from the same page, you’ll get a second Brave audio slider.
  7. Slide that Brave slider all the way down to zero and go back to your the page with your sound source and play it again. Now you don’t even have any sound coming out of your system speakers! If you have two Brave audio sliders you can really experiment! But as soon as you navigate away from the page with the source videos, those Brave sliders disappear.
    I expect some Nerd to come on here and say this cannot happen because Brave has no impact or effect on the system settings. I’m NOT supposed to believe my lying ears and eyes.
But what I would LIKE is for Brave developers to fix the problem. It comes up on numerous platforms. And simply closing a discussion after not solving it for 30 days is NOT a solution. It’s just a dismissal of the problem all these prior folks have brought attention to.
1.76.82
Brave is my first-choice browser everywhere.
To make such an assertion you would have to find the X11/Wayland API documentation to see whether the user’s per-app audio setting is reported to the app, and also check to see if Brave does anything when provided with that information. It works on Fedora, which is a strong suggestion that the latter is not the case, even if the former is.
Brave has had no audio for me for a few weeks now, I’ve no idea what update killed it. I’m using Vivaldi or Chromium now if I want sound. YouTube and Rumble have no sound in Brave v 1.766.82 on Fedora 41 with all updates but they work fine in the other browsers. It might have happened when pipewire was updated.
For me it’s a simple setup, old wired speakers plugged into the speaker port, no bluetooth. It’s perhaps some setting but I’ve not figured it out yet, I just use other browsers if need be.
I’ve not had many pipewire upgrades since buying my current laptop in October last year: one in November, one in February, and then two in March 5 days apart. Those last two being so close together looks out of place, so there might have been something wrong with the first release, but I had no audio or bluetooth issues during that period.
I’m currently using pipewire-0:1.2.7-7.fc41, while the February upgrade (which I assume was your last working version) was to pipewire-0:1.2.7-4.fc41. If you’re not on the latest version you should upgrade. There are some risks in downgrading or rolling back, but if the latest version doesn’t work it could be worthwhile backing up and trying that.
You can find package upgrade history with
sudo dnf history info 1..last --reverse --contains-pkgs=pipewire
Thanks, I gave the pipewire downgrade a try but it didn’t help. For now I just have a workaround of using an alternative browser. I generally stay current with Fedora and apply all the updates so I am running the most up to date brave and pipewire along with everything else.
When audio stopped working it took me a bit to realize it was only Brave and everything else was fine. I thought a subsequent update would correct it but that’s not been the case. I thought it could be related to Youtube’s recent adblocker changes but rumble doesn’t work either.
So I just tried to downgrade pipewire, restart Brave, and tested it. No change. I just went back to the current pipewire.
That didn’t work but thanks much for the helpful suggestions.
Full boring details are appended below
Upgrading:
brave-browser x86_64 1.77.95-1 brave-brows 390.5 MiB
replacing brave-browser x86_64 1.76.82-1 brave-brows 388.3 MiB
Transaction Summary:
Upgrading: 1 package
Replacing: 1 package
Total size of inbound packages is 121 MiB. Need to download 121 MiB.
After this operation, 2 MiB extra will be used (install 390 MiB, remove 388 MiB).
Is this ok [y/N]: y
[1/1] brave-browser-0:1.77.95-1.x86_64 100% | 9.6 MiB/s | 120.5 MiB | 00m13s
[1/1] Total 100% | 9.6 MiB/s | 120.5 MiB | 00m13s
Running transaction
[1/4] Verify package files 100% | 3.0 B/s | 1.0 B | 00m00s
[2/4] Prepare transaction 100% | 3.0 B/s | 2.0 B | 00m01s
[3/4] Upgrading brave-browser-0:1.77.95 100% | 26.4 MiB/s | 390.5 MiB | 00m15s
[4/4] Removing brave-browser-0:1.76.82- 100% | 86.0 B/s | 246.0 B | 00m03s
Complete!
root@Sparky37:~# rpm -a | grep pipewire
root@Sparky37:~# rpm -qa | grep pipewire
vlc-plugin-pipewire-3-4.fc41.x86_64
kpipewire-6.3.3-1.fc41.x86_64
pipewire-libs-1.2.7-7.fc41.x86_64
pipewire-1.2.7-7.fc41.x86_64
pipewire-jack-audio-connection-kit-1.2.7-7.fc41.x86_64
pipewire-jack-audio-connection-kit-libs-1.2.7-7.fc41.x86_64
pipewire-utils-1.2.7-7.fc41.x86_64
pipewire-pulseaudio-1.2.7-7.fc41.x86_64
pipewire-plugin-libcamera-1.2.7-7.fc41.x86_64
pipewire-gstreamer-1.2.7-7.fc41.x86_64
pipewire-alsa-1.2.7-7.fc41.x86_64
qemu-audio-pipewire-9.1.3-2.fc41.x86_64
root@Sparky37:~# dnf downgrade pipewire pipewire-libs pipewire-alsa pipewire-utils pipewire-pulseaudio
Updating and loading repositories:
Repositories loaded.
Package Arch Version Reposit Size
Downgrading:
pipewire x86_64 1.2.5-1.fc41 fedora 398.8 KiB
replacing pipewire x86_64 1.2.7-7.fc41 updates 401.8 KiB
pipewire-alsa x86_64 1.2.5-1.fc41 fedora 138.0 KiB
replacing pipewire-alsa x86_64 1.2.7-7.fc41 updates 138.0 KiB
pipewire-gstreamer x86_64 1.2.5-1.fc41 fedora 145.2 KiB
replacing pipewire-gstreamer x86_64 1.2.7-7.fc41 updates 149.2 KiB
pipewire-jack-audio-connection-kit x86_64 1.2.5-1.fc41 fedora 30.0 B
replacing pipewire-jack-audio-connection-kit x86_64 1.2.7-7.fc41 updates 30.0 B
pipewire-jack-audio-connection-kit-libs x86_64 1.2.5-1.fc41 fedora 464.7 KiB
replacing pipewire-jack-audio-connection-kit-libs x86_64 1.2.7-7.fc41 updates 464.7 KiB
pipewire-libs x86_64 1.2.5-1.fc41 fedora 7.2 MiB
replacing pipewire-libs x86_64 1.2.7-7.fc41 updates 7.2 MiB
pipewire-plugin-libcamera x86_64 1.2.5-1.fc41 fedora 134.5 KiB
replacing pipewire-plugin-libcamera x86_64 1.2.7-7.fc41 updates 142.5 KiB
pipewire-pulseaudio x86_64 1.2.5-1.fc41 fedora 423.9 KiB
replacing pipewire-pulseaudio x86_64 1.2.7-7.fc41 updates 423.9 KiB
pipewire-utils x86_64 1.2.5-1.fc41 fedora 1.1 MiB
replacing pipewire-utils x86_64 1.2.7-7.fc41 updates 1.1 MiB
Replacing: 9 packages
Downgrading: 9 packages
Total size of inbound packages is 3 MiB. Need to download 3 MiB.
After this operation, 27 KiB will be freed (install 10 MiB, remove 10 MiB).
Is this ok [y/N]: y
[1/9] pipewire-plugin-libcamera-0:1.2.5 100% | 205.8 KiB/s | 72.9 KiB | 00m00s
[2/9] pipewire-alsa-0:1.2.5-1.fc41.x86_ 100% | 129.8 KiB/s | 57.9 KiB | 00m00s
[3/9] pipewire-pulseaudio-0:1.2.5-1.fc4 100% | 361.4 KiB/s | 206.7 KiB | 00m01s
[4/9] pipewire-0:1.2.5-1.fc41.x86_64 100% | 191.3 KiB/s | 130.3 KiB | 00m01s
[5/9] pipewire-jack-audio-connection-ki 100% | 21.2 KiB/s | 15.5 KiB | 00m01s
[6/9] pipewire-utils-0:1.2.5-1.fc41.x86 100% | 447.9 KiB/s | 353.8 KiB | 00m01s
[7/9] pipewire-gstreamer-0:1.2.5-1.fc41 100% | 81.9 KiB/s | 70.1 KiB | 00m01s
[8/9] pipewire-jack-audio-connection-ki 100% | 147.6 KiB/s | 137.6 KiB | 00m01s
[9/9] pipewire-libs-0:1.2.5-1.fc41.x86_ 100% | 1.6 MiB/s | 1.9 MiB | 00m01s
[9/9] Total 100% | 1.7 MiB/s | 3.0 MiB | 00m02s
Running transaction
[ 1/20] Verify package files 100% | 900.0 B/s | 9.0 B | 00m00s
[ 2/20] Prepare transaction 100% | 36.0 B/s | 18.0 B | 00m00s
[ 3/20] Downgrading pipewire-libs-0:1.2 100% | 2.9 MiB/s | 7.3 MiB | 00m03s
[ 4/20] Downgrading pipewire-0:1.2.5-1. 100% | 1.6 MiB/s | 405.1 KiB | 00m00s
[ 5/20] Downgrading pipewire-jack-audio 100% | 4.4 MiB/s | 467.3 KiB | 00m00s
[ 6/20] Downgrading pipewire-jack-audio 100% | 5.3 KiB/s | 312.0 B | 00m00s
[ 7/20] Downgrading pipewire-utils-0:1. 100% | 2.4 MiB/s | 1.1 MiB | 00m00s
[ 8/20] Downgrading pipewire-alsa-0:1.2 100% | 919.0 KiB/s | 139.7 KiB | 00m00s
[ 9/20] Downgrading pipewire-pulseaudio 100% | 1.7 MiB/s | 431.9 KiB | 00m00s
[10/20] Downgrading pipewire-plugin-lib 100% | 716.1 KiB/s | 135.3 KiB | 00m00s
[11/20] Downgrading pipewire-gstreamer- 100% | 1.4 MiB/s | 145.9 KiB | 00m00s
[12/20] Removing pipewire-jack-audio-co 100% | 88.0 B/s | 17.0 B | 00m00s
[13/20] Removing pipewire-utils-0:1.2.7 100% | 574.0 B/s | 77.0 B | 00m00s
[14/20] Removing pipewire-0:1.2.7-7.fc4 100% | 554.0 B/s | 41.0 B | 00m00s
[15/20] Removing pipewire-gstreamer-0:1 100% | 37.0 B/s | 4.0 B | 00m00s
[16/20] Removing pipewire-pulseaudio-0: 100% | 444.0 B/s | 48.0 B | 00m00s
[17/20] Removing pipewire-alsa-0:1.2.7- 100% | 108.0 B/s | 10.0 B | 00m00s
[18/20] Removing pipewire-plugin-libcam 100% | 54.0 B/s | 5.0 B | 00m00s
[19/20] Removing pipewire-jack-audio-co 100% | 15.0 B/s | 1.0 B | 00m00s
[20/20] Removing pipewire-libs-0:1.2.7- 100% | 27.0 B/s | 377.0 B | 00m14s
Complete!
root@Sparky37:~# rpm -qa | grep brave
brave-keyring-1.15-1.noarch
brave-browser-1.77.95-1.x86_64
root@Sparky37:~# killall brave
root@Sparky37:~# dnf update pipewire pipewire-libs pipewire-alsa pipewire-utils pipewire-pulseaudio
Upgrading:
replacing pipewire x86_64 1.2.5-1.fc41 fedora 398.8 KiB
replacing pipewire-alsa x86_64 1.2.5-1.fc41 fedora 138.0 KiB
replacing pipewire-gstreamer x86_64 1.2.5-1.fc41 fedora 145.2 KiB
replacing pipewire-jack-audio-connection-kit x86_64 1.2.5-1.fc41 fedora 30.0 B
replacing pipewire-jack-audio-connection-kit-libs x86_64 1.2.5-1.fc41 fedora 464.7 KiB
replacing pipewire-libs x86_64 1.2.5-1.fc41 fedora 7.2 MiB
replacing pipewire-plugin-libcamera x86_64 1.2.5-1.fc41 fedora 134.5 KiB
replacing pipewire-pulseaudio x86_64 1.2.5-1.fc41 fedora 423.9 KiB
replacing pipewire-utils x86_64 1.2.5-1.fc41 fedora 1.1 MiB
Upgrading: 9 packages
After this operation, 27 KiB extra will be used (install 10 MiB, remove 10 MiB).
Is this ok [y/N]: y
[1/9] pipewire-plugin-libcamera-0:1.2.7 100% | 206.8 KiB/s | 73.6 KiB | 00m00s
[2/9] pipewire-jack-audio-connection-ki 100% | 28.6 KiB/s | 13.9 KiB | 00m00s
[3/9] pipewire-pulseaudio-0:1.2.7-7.fc4 100% | 369.0 KiB/s | 205.2 KiB | 00m01s
[4/9] pipewire-jack-audio-connection-ki 100% | 218.6 KiB/s | 136.2 KiB | 00m01s
[5/9] pipewire-gstreamer-0:1.2.7-7.fc41 100% | 93.8 KiB/s | 68.6 KiB | 00m01s
[6/9] pipewire-alsa-0:1.2.7-7.fc41.x86_ 100% | 61.7 KiB/s | 56.5 KiB | 00m01s
[7/9] pipewire-0:1.2.7-7.fc41.x86_64 100% | 130.7 KiB/s | 129.6 KiB | 00m01s
[8/9] pipewire-utils-0:1.2.7-7.fc41.x86 100% | 323.2 KiB/s | 352.6 KiB | 00m01s
[9/9] pipewire-libs-0:1.2.7-7.fc41.x86_ 100% | 1.2 MiB/s | 1.9 MiB | 00m02s
[9/9] Total 100% | 1.5 MiB/s | 2.9 MiB | 00m02s
Running transaction
[ 1/20] Verify package files 100% | 529.0 B/s | 9.0 B | 00m00s
[ 2/20] Prepare transaction 100% | 37.0 B/s | 18.0 B | 00m00s
[ 3/20] Upgrading pipewire-libs-0:1.2.7 100% | 5.4 MiB/s | 7.3 MiB | 00m01s
[ 4/20] Upgrading pipewire-0:1.2.7-7.fc 100% | 2.1 MiB/s | 408.1 KiB | 00m00s
[ 5/20] Upgrading pipewire-jack-audio-c 100% | 4.5 KiB/s | 312.0 B | 00m00s
[ 6/20] Upgrading pipewire-jack-audio-c 100% | 4.5 MiB/s | 467.4 KiB | 00m00s
[ 7/20] Upgrading pipewire-utils-0:1.2. 100% | 3.9 MiB/s | 1.1 MiB | 00m00s
[ 8/20] Upgrading pipewire-pulseaudio-0 100% | 2.3 MiB/s | 431.9 KiB | 00m00s
[ 9/20] Upgrading pipewire-plugin-libca 100% | 1.7 MiB/s | 143.4 KiB | 00m00s
[10/20] Upgrading pipewire-gstreamer-0: 100% | 2.2 MiB/s | 149.9 KiB | 00m00s
[11/20] Upgrading pipewire-alsa-0:1.2.7 100% | 759.3 KiB/s | 139.7 KiB | 00m00s
[12/20] Removing pipewire-utils-0:1.2.5 100% | 836.0 B/s | 77.0 B | 00m00s
[13/20] Removing pipewire-0:1.2.5-1.fc4 100% | 356.0 B/s | 41.0 B | 00m00s
[14/20] Removing pipewire-alsa-0:1.2.5- 100% | 133.0 B/s | 10.0 B | 00m00s
[15/20] Removing pipewire-gstreamer-0:1 100% | 53.0 B/s | 4.0 B | 00m00s
[16/20] Removing pipewire-pulseaudio-0: 100% | 640.0 B/s | 48.0 B | 00m00s
[17/20] Removing pipewire-jack-audio-co 100% | 13.0 B/s | 1.0 B | 00m00s
[18/20] Removing pipewire-jack-audio-co 100% | 238.0 B/s | 16.0 B | 00m00s
[19/20] Removing pipewire-plugin-libcam 100% | 74.0 B/s | 5.0 B | 00m00s
[20/20] Removing pipewire-libs-0:1.2.5- 100% | 59.0 B/s | 372.0 B | 00m06s
Complete!
OK, another update. I removed my entire Brave-Browser configuration and tried to play a Youtube video in a brand new instance. Essentially I renamed /.config/Brave-Browser, did a killall brave, and restarted it. I got a new Brave window without any cookies, bookmarks, history, or anything else. Still no sound. Following that failed idea I just did another killall and restored the old .config directory to get back to what I had.
I am just curious why it’s failed, with hardly any other reports I can find, and no solutions. I always have my workarounds of other browsers, or yt-dlp and vlc to download and play whatever I like. From my perspective Brave is broken but anyone is welcome to correct me.
Is Brave muted in Sound > Volume levels?
I just muted Chrome while playing Soundcloud, then closed the app, reopened it and played Rumble. It was still muted.
I looked about and I only found this one place where sound settings are configured on my Fedora install. There’s nothing set for Brave. I then installed the pulseaudio control utility and checked to be sure there was nothing set there either.
Well, in that image my sound shows as muted but I routinely turn it on and off from the menu bar.
